Smoky dipstick?
Old Mar 23, 2012 | 11:56 AM
bostongrun's Avatar
Default Smoky dipstick?
My cousin bought a 1995 850t with 132k, I observed that it had the infamous smokey dipstick and breather. I throughly cleaned the oil seperator box by remvoing it, soaking it in gas for an hour, then running presurized water through all the outlets and inlets to make sure it flowed good. I also cleaned all the hoses and the PTC valve. Even after all this it stills smokes from the breather and dipstick.
I assumed that the smoking was casued by blowby; an old worn out engine. I did a compressin test and got 120, 120, 120, 120, 115. Not bad at all for an old motor. The plugs also looked fine greyish brown
The car runs great. Any ideas?
Old Mar 23, 2012 | 12:03 PM
slimflex2's Avatar
did you clean the holes on the engine block? sometimes they get pretty clogged up too and end up still having smoking dipstick.
Old Mar 23, 2012 | 12:11 PM
Change the parts. Usually 1 line is clogged causing the smoke. You also need to make sure you clean out the ports on the block, etc.
Did you do the compression test with the motor warm? How about a wet test? The numbers are pretty even but should be between 156 - 185. 135,000 Miles is nothing for that motor. I have over 200,000 on mine, some get as much as 500,000.
Old Mar 23, 2012 | 09:52 PM
Turkey_Sandwich's Avatar
The compression is pretty out of spec. I have 100K on ya, and my numbers average about 160 PSI across the board on the turbo car.
gilber33
Jul 22, 2009 02:23 PM
Marks 240
Dec 6, 2005 08:48 PM
bumblebee03
Sep 8, 2005 11:39 PM
POR2
Jun 17, 2005 07:34 PM
johnboy1967
Mar 27, 2005 12:25 PM
