startup issues
Old Jun 28, 2010 | 05:22 PM
kapka42's Avatar
Default startup issues
Every now and then (maybe once every 1-2months) my 95 850 would have trouble starting. The motor would crank but not roll over. Usually waiing a minute and then trying would work.
Today tho its happened 3 times (always after the engines warmed up). Each time the engine will initially roll over to idle, then slowly sputter out. When i try to start it, i hear the thing cranking desperately trying to start. Once i finally get it to start, it runs fine and when i get home and turn it off, it can be started again immediatly after.
Anyone have this problem before or know whats causing it?
Old Jun 28, 2010 | 11:46 PM
gdog's Avatar
Could be any number of things but given the symptoms, first thing I would suspect would be fuel pump relay giving you intermittent service.
You could attach a fuel pressure gauge to monitor it; alternatively you wire up a test light to the output of the fuel pump relay; if the test light goes out when you car won't start then you know what's going on...
Old Jun 29, 2010 | 12:16 PM
kapka42's Avatar
how would i go about wiring up a testlight? i have the relay itself out of the car but dont really know where to go from there
burrowspj
Sep 16, 2013 09:10 PM
kapka42
May 31, 2009 04:06 PM
jdbs3
Feb 3, 2009 05:11 AM
ajvpb
Jan 4, 2006 10:22 PM
Kruspe31
Dec 13, 2005 09:17 PM
