Steering column alignment
Old Nov 28, 2007 | 02:10 PM
jollygoodgold's Avatar
Default Steering column alignment
My 96 850 Turbo has a cocked steering wheel. It sits off centered, slightly to the right. When I align my steering wheel perfectly forward, it veers to the left, to get it to go straight, I have to have the steering wheel slightly to the left. Can I adjust it? Or is it a power steering problem? It happened after hoisting my car up, I got an alignment, it didn’t help. What can I do? Thanks guys.
Old Nov 28, 2007 | 02:54 PM
JimKW's Avatar
Default RE: Steering column alignment
Take it back to whoever aligned it and have them get it right. It's their fault.
Old Nov 28, 2007 | 02:59 PM
jks2's Avatar
Generally you can get them to line up. It sounds like when they had the wheels off they may have disconnected the rack and the steering wheel turned and then when they put it back together you ended up with your current problem. I agree with JimKW, take it back to whoever did the work and ask them to correct it.
Old Nov 28, 2007 | 06:12 PM
ORIGINAL: JimKW
+1
Old Nov 30, 2007 | 07:18 PM
robrike's Avatar
Yep, someone messed up when they aligned it before. Normally they put a wedge thing between the wheel and the seat with the wheel perfectly centered. Then they align the front and rear wheels to the steering wheel. At least that is what they have done on mine. Sounds like they forgot to center your wheel. Take it back to them, it should have been obvious to the Technician when he test drove it after the alignment. Had it happen acouple times to me before and it always goes back and the managers never argued. I think they just assume the average person won't complain.
texan_176
Sep 2, 2009 09:07 PM
W35
Aug 12, 2009 08:22 PM
Sota
Jun 4, 2009 12:59 PM
Robonorm
Nov 5, 2008 07:20 AM
novablue69
Dec 28, 2006 09:57 AM
