Indicator Stem on Steering Column
Old Nov 5, 2008 | 12:33 AM
Robonorm's Avatar
Default Indicator Stem on Steering Column
Hi Guys,
The turn indicator stick is not going easily to the right turn position, thats up the way.
It needs a sharp push to make it go. Also the auto cancelling is not working.
How can I get the housing apart to see the mechanism. The housing between the wheel and the instruments.
Several things seem to be going wrong at the same time on my 2003 model.
Thanks.
Old Nov 5, 2008 | 07:20 AM
Default RE: Indicator Stem on Steering Column
You need to remove the upper and lower covers. There is screws from the bottom.
Either the turn signal switch is bad or the SRS contact reel.
texan_176
Sep 2, 2009 09:07 PM
W35
Aug 12, 2009 08:22 PM
Sota
Jun 4, 2009 12:59 PM
jollygoodgold
Nov 30, 2007 07:18 PM
novablue69
Dec 28, 2006 09:57 AM
