Stock stereo
Old Feb 5, 2012 | 01:49 AM
izinux's Avatar
Default Stock stereo
I'm thinking about upgrading the stereo in my 850r, has anyone ran into issues replacing the deck or the speakers ? And where is the amp located ?
Another thing does the original deck have anywhere to plug in an aux for a 3.5mm jack. I don't really want to use a cassette adapter until i switch out the deck.
Old Feb 5, 2012 | 10:09 AM
MattyXXL's Avatar
OEM deck has an input in the back for a changer, there is an iPod adapter made that plugs into that port if that is what you are looking for.
Replacement is extremely easy, just make sure you have all the required components... ie;
Harness adapter to connect the new unit (DO NOT I repeat DO NOT cut the factory harness!!)
Single din adapter if your going single din.
depending on what head unit you go with make sure you have a space for sat radio adapter, Bluetooth, nav, and such if your new head unit requires it..
Go to crutchfield.com and enter the Volvo info, it will show you all that fits.
If you order from them they give you all that you need for the install as well as instructions, and live FREE installation support.
Old Feb 5, 2012 | 05:54 PM
izinux's Avatar
Thanks Matt ! Do you know the adapter I need to plug in an iPod ?
Old Feb 5, 2012 | 06:13 PM
MattyXXL's Avatar
Same one IPD sells for $70 cheaper
http://www.amazon.com/USA-PA11-VOL-F...8487044&sr=8-1
codeMonkey
May 7, 2008 01:05 PM
KnoxVolvo
Dec 24, 2007 08:36 AM
bpuente
Nov 14, 2007 04:05 PM
NCS60
Feb 20, 2007 01:49 PM
domcren12
Jun 16, 2006 04:29 AM
