Strange noise when I turn off Volvo 850 engine
Old Sep 28, 2012 | 07:58 AM
VanaVolvo's Avatar
Default Strange noise when I turn off Volvo 850 engine
Hi,
There is strange noise when I turn engine off and it comes somewhere driver part of engine. I recorded it an you can hear it here http://andruskannel.planet.ee/volvo_...ylitamisel.mp3
or http://andruskannel.planet.ee/volvo_mootor/
Recording may be weak so you need to turn on volume. Can anybody say me what makes that noise.
Thank You
Andrus
Old Sep 28, 2012 | 12:13 PM
boxpin's Avatar
File not found
Old Sep 28, 2012 | 01:23 PM
vjaneczko's Avatar
Sounds like something metalic is rattling around at the end, is that what you mean? Sounds like something vibrates when you shut the engine off - maybe a hose clamp or something connected to the MAF? Are you able to give a better indication as to the location of the noise?
Old Sep 28, 2012 | 01:25 PM
VanaVolvo's Avatar
Thank you boxpin pointing out broken link. I edited it, hopefully it works now.
Old Sep 28, 2012 | 01:36 PM
VanaVolvo's Avatar
vjaneczko, yes I mean that metalic rattling sound. There is nothing to see in naked eye and all clamps look okey. I suspect that this sound comes inside motor or clutch or maybe inside gearbox. But I dont know. But what is MAF?
Old Sep 28, 2012 | 06:55 PM
VTBricked's Avatar
Buy a mechanic's stethoscope to clearly isolate the noise.
Old Sep 28, 2012 | 10:33 PM
slimflex2's Avatar
But what is MAF?[/QUOTE]
MASS AIR FLOW. THATS WHATS IT MEANS. TAKING A VIDEO WILL BE A GOOD IDEA
Old Sep 29, 2012 | 06:03 AM
VanaVolvo's Avatar
Thank you slimflex2. I made video though I think it does not give answers. I let you know if I figure out what makes that noise.
Old Sep 30, 2012 | 12:15 AM
gdog's Avatar
Video Volvo 850 engine makes rattling sound in the end .avi - YouTube
Don't recall ever hearing a noise like that. But it does sound like something metallic rattling. I would crawl around the engine (off) bay with a mallet and smacking stuff (carefully; don't break anything!) till I could reproduce that sound.
Old Sep 30, 2012 | 07:32 AM
Almost sounds like a loose flywheel to me. Hopefully it's something to do with the exhaust.
Old Sep 30, 2012 | 01:34 PM
The mass air flow sensor is attached to the air cleaner housing and is used by the engine management computer to calculate how much air is entering the engine. It does this by using a "hot wire" in the center of the sensor. If the wire gets dirty from lack of timely air filter replacement or contaminated with oil from an oiled air filter it will send an erroneous signal and cause poor running. They can be cleaned and sometimes that will bring them back to life. You want to use a cleaner made for them and not just brake or carb cleaner.
Attached Thumbnails Strange noise when I turn off Volvo 850 engine-mass-air-flow-sensor.jpg   Strange noise when I turn off Volvo 850 engine-mass-air-flow-cleaner.jpg
Old Sep 30, 2012 | 02:11 PM
It sounds like a bad serpentine or timing belt system bearing or the AC clutch. It's such a loose metallic sound it's hard to pin down. I'd pull the serpentine belt off and spin all the things it turns to see if you come up with something loose. It does sound a lot like a bad or loose AC clutch assembly or bearing. If nothing I'd pull the timing cover to get to the T belts tensioner and idler to see if it's one of them.
Old Oct 1, 2012 | 03:00 PM
VanaVolvo's Avatar
I got a lot of good answers here. Thank you for everyone.
Old Oct 1, 2012 | 03:04 PM
LOL, which answers were good? Did any of them help you fix it?
Old Oct 5, 2012 | 06:12 AM
VanaVolvo's Avatar
Finally I can say what makes that noise. This is Clutch Release Bearing that makes noise. Thank You took time to help me and I remove the video in YouTube.
Old Oct 10, 2012 | 08:00 AM
V850R's Avatar
Mine has just started to make this noise occasionally now too...
Old Oct 10, 2012 | 04:11 PM
  #17
Lynn_B's Avatar
My suggestion was going to be a loose alternator cooling fan ring. Happened to me many years ago. The little stamped "fan" turbine on the alternator of an elderly vehicle turned loose from its attachment behind the alternator pulley. The noise it made from the time the key was turned until the engine started was covered up by the rest of the engines noise (loud pipes, etc. I've grown up some since then.). The rest of the time, it would sling itself slightly off center and stay there. When the engine was turned off, it would rattle and clang for two or three seconds, then stop. Nothing broke, no smoke, everything worked, and it stopped quickly enough after I killed the engine that I couldn't see what was causing the noise by the time I got my head under the hood. So I didn't worry about it. A buddy pointed it out one afternoon while we were tuning the engine for the upcoming Saturday night cruise. The alternator lasted longer than the rest of the car did, so it was never an issue, just an annoyance.
Lynn B.
Mycophiles
Jun 25, 2014 01:46 PM
Mycophiles
May 20, 2014 08:31 AM
VanaVolvo
Sep 28, 2012 07:48 AM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
