Strong gas fumes?
Old Feb 1, 2016 | 03:34 PM
rcvolvo's Avatar
Default Strong gas fumes?
Just started driving my 96 850 GLT N/A after being in the garage for a couple months waiting for new tires. I did drive it occasionally but up until the last couple of days the smell of gas was so strong I had to pull it outside. I cannot find any leaks from underneath or on the floor. Anyone have any experience with a problem like this? I hope its' something common I just don't' know where to start other than the fuel filter. Thanks.
Old Feb 1, 2016 | 04:34 PM
boxpin's Avatar
Vent hose on top of the tank. Common problem. You have to drop the tank to replace it. Really not that bad of a job.
Old Feb 1, 2016 | 05:08 PM
You might also want to check the area of the fuel pressure regulator in case a line loosened up. The heater can pull those fumes from the raw gas right into the car.
Old Feb 1, 2016 | 05:39 PM
rcvolvo's Avatar
Hi boxpin, Can I order a new hose or did the old one just come loose? And while I'm there what do you think about fuel pump and sensor ? The tank is full of gas.
Old Feb 1, 2016 | 05:41 PM
rcvolvo's Avatar
Hi kiss4afrog, I haven't noticed any smell from the inside of cabin but have not driven the car except from tire shop to the garage.
Old Feb 2, 2016 | 03:36 PM
boxpin's Avatar
Cracked. No need to do anything with the pump or sender, they both have access panels anyway.
Ahmed
Jun 6, 2011 08:41 PM
d33dvb
Jan 13, 2010 10:46 PM
jg1
Nov 1, 2007 10:40 AM
pierre
Oct 20, 2007 07:37 PM
huzzsaba
Mar 7, 2007 02:30 AM
