stuck on Front brake job 94-855..help!
Old Dec 1, 2007 | 04:24 PM
atownpdx's Avatar
Default stuck on Front brake job 94-855..help!
Doing front brake job on a 1994 855 Turbo
I got one side all done, easy as cake. I am putting back together the other side and like the first side I need to use some pliers to push the piston back into its home a little so I can fit the pads in the caliper enough to fit around the rotor. The problem is on this side that it wont go back in, even a little. I am a pretty strong guy and I cant get it to budge.Have a manual for the car and I looked at that but it suggests the same thing we've done. Push it back in with pliers is what is says.
Anyone have any ideas? Do I need to take the other side apart again? Seems like it could be a back and forth game if I do that.
Any help appreciated. THANKS
Old Dec 1, 2007 | 05:21 PM
wallie's Avatar
Default RE: stuck on Front brake job 94-855..help!
Make sure you have the cap off of the master cylinder resevoir, you want to remove some brake fluid so it doesn't overflow when you collapse the caliper. A pair of pump pliers big enough to grab the back of the caliper and the face of the piston at the same time works good. Try a little penetrating oil.
Old Dec 1, 2007 | 09:42 PM
m1964's Avatar
You can try pulling the piston out/ or just press the brake pedal to push the piston out of the caliper.
After removing the piston look inside the caliper for dirt/etc., cleanthe caliper and piston well, lubricate the seals inside the caliper and try pushing piston back in. If it works, you will have to bleed the system.
I did it once (pushed piston out) by mistake by pressing brake pedal...
buelts
Jan 8, 2021 10:30 AM
PaddyG
1998-2000 model year V70
Feb 17, 2014 05:23 PM
I8ASaleen
Oct 3, 2013 02:43 AM
sotlm2noles
Dec 13, 2010 07:55 PM
master_pre
Sep 30, 2006 04:35 PM
