switched out air filter and now car idles rough
Old Mar 1, 2014 | 02:25 PM
olyboy2010's Avatar
Angry switched out air filter and now car idles rough
hey guys i have 1995 volvo 850 glt n/a 20valve
i recently moved to California and had to smog my car. i pass everything and almost got the green light but for one thing. i didnt have a sticker for my air intake so i failed , sooo i go out and buy a "Legal" intake and i put it on, while i was installing the new filter, i unplugged the maf???( the one between the intake and the throttle body) sensor and put everything back on and forgot to plug it back in. i noticed after i started the car it was unplugged and plugged it back in now its tripping the check engine light and running rough and wont idle smoothly,it also lunges and lerks when i slow down and apply the brakes.
what going on?????????????
Old Mar 1, 2014 | 04:40 PM
kyle17428's Avatar
You need to clear the computer. It thinks the maf is still faulty and is trying to compensate.
Old Mar 1, 2014 | 05:38 PM
olyboy2010's Avatar
how would you do that????
Old Mar 1, 2014 | 10:18 PM
oragex's Avatar
Unplug positive cable at battery for 12h (night long)
Old Mar 1, 2014 | 10:57 PM
olyboy2010's Avatar
will give it a try
thanks
is that the only way to completely reset this beast lol
Old Mar 2, 2014 | 03:38 PM
Do you still have the check engine light on ??
Old Mar 2, 2014 | 06:03 PM
olyboy2010's Avatar
yes i do
Old Mar 2, 2014 | 09:52 PM
You should be able to reset the code with this...
Old Mar 4, 2014 | 12:09 AM
olyboy2010's Avatar
so if i clear the code will it reset and return my idle to normal and smooth running????
Old Mar 4, 2014 | 12:27 AM
olyboy2010's Avatar
i have a code of A2-223
Old Mar 4, 2014 | 01:25 AM
You need to clear the codes and see if it resets. If it resets you still have a problem. If you've already replaced the sensor than it might be in the connector at the sensor or the wiring between the sensor and the ECM or even a bent pin or dirty/tarnished connection at the ECMs connector.
debargha
Feb 24, 2015 10:46 PM
clashboy
1998-2000 model year V70
Sep 17, 2013 06:58 PM
cyrusyn
Jul 2, 2012 03:55 AM
weirdwaldo
Oct 17, 2010 02:57 PM
skidkid64
Jul 19, 2007 11:34 PM
