Car Idles rough then stalls
Old Jul 14, 2007 | 10:35 AM
skidkid64's Avatar
Default Car Idles rough then stalls
My son had a tune up, new fuel pump, new engine mounts and several gaskets replaced. But now the car idles rough and stalls when your foot is taken off the gas pedal, it also has very slow acceleration and shifting is slow but the transmission seems to be working alright. My son gave the car to me and I'd hate to junk it for something possibly simple. Please help if anyone has info on these problems.
91/740/Sedan
Old Jul 14, 2007 | 08:14 PM
basecamper's Avatar
Default RE: Car Idles rough then stalls
Fuel filters changed as well?
Old Jul 15, 2007 | 09:59 AM
JAKESTERS's Avatar
when someone did the air filter change may have pull the wires from the Van air meter,just enought to not give you correct reading. The plug that goes right in the air box, pull rubber booth back and check. any engine lights ,codes? Vacuum leaks?
Old Jul 15, 2007 | 11:49 AM
Kruspe31's Avatar
its not called van meter, itas called Mass air flow sensor. It can be expensive if you need a new one. I am pretty sure you can test it with a dvom
Old Jul 16, 2007 | 01:31 AM
Beardog's Avatar
try cleaning the Idle air control valve. It helped with mine. Then go and clean the MAF and then clean the throttle body. If these three things dont fix the problem then look to the the fuel sensor relay thats with the fuses.
Old Jul 17, 2007 | 07:11 AM
outofworkjoe's Avatar
Look around for airleaks,loose hose ex ex .check your intank hose for cracks.I had an problem like that this hose had an crack in the rib ,I was going to replace the Amm and saw this hose has was cracked .I replaced it end of problems.
Old Jul 19, 2007 | 11:34 PM
Kruspe31's Avatar
does the car have an iat? intake air tempertaure. if so check that maybe its running very lean is there any white smoke?
olyboy2010
Mar 4, 2014 01:25 AM
tripj33
Jan 29, 2014 01:28 PM
petmbro
Dec 17, 2013 01:44 PM
clashboy
1998-2000 model year V70
Sep 17, 2013 06:58 PM
estreet1
Jan 16, 2012 01:33 PM
