Tightening Parking Brake Cable
Old Nov 14, 2005 | 10:51 AM
jcmartin's Avatar
Default Tightening Parking Brake Cable
Has anyone tightened the parking brake on an 850? From the documentation I can find it looks like a very difficult operation.
Thanks,
JM
Old Nov 14, 2005 | 08:59 PM
Default RE: Tightening Parking Brake Cable
Open the center console lid (Arm rest lid) then remove the little cover in the bottom of the cubby.Then you should see a Torxes screw towards the front of the hole. That adjusts the E-brake cable.
Old Jan 7, 2011 | 03:10 PM
endneu913's Avatar
That's a Huge torx! FYI... bigger than a 40, handy to have it as a torx bit on a ratchet. But my handheld 40 worked ok, just a sloppy job. lol
I assume after a few cycles of adjustment that it would be time to change the rear pads correct?
- Grae
Old Jan 7, 2011 | 03:20 PM
vjaneczko's Avatar
Actually, it's not a torx but a metric hex - but it sounds like you got it
The pads will probably last a very long time since you use them to keep the car from rolling as opposed to 'real' brake pads that stop a car. The pads will probably fall off the metal braket before the pad material is worn away - unless you use 'em to make the car slide a lot. Most likely if you tighten it up a few times, it's either just getting loose or the cable is stretching.
Old Jan 7, 2011 | 05:06 PM
ibified's Avatar
vj: who would EVER use an e-brake to slide a car around a lot? especially in the snow?
Old Jan 7, 2011 | 05:07 PM
endneu913's Avatar
Curious. I wonder if different model years had a different type of tool used. Mine is for sure a Torx!
Old Jan 7, 2011 | 05:09 PM
vjaneczko's Avatar
um, you know . . . kids?
I don't wanna grow up, I'm a toys r us kid . . .
Old Jan 8, 2011 | 01:00 AM
endneu913's Avatar
......................doh! maybe thats why mine got so loose! : )
Psaboic
Aug 28, 2018 04:02 PM
kapka42
Jun 29, 2011 01:25 PM
wcthrel5
Mar 10, 2009 09:11 PM
S70GLT
Oct 9, 2008 07:19 AM
LP_Tango
Sep 15, 2008 08:14 AM
