Tightening e-brake cable
Old Oct 6, 2008 | 05:36 PM
S70GLT's Avatar
Default Tightening e-brake cable
I can lift the lever all the way to the last notch, and while at a crawl it feels as though very little pressure is being asserted on the brakes.
Just wondering if tightening the tension of my ebrake cable is something that I can do on my own with common tools or something I have to go to the dealership with.. If it can be done on my own, how so?
Thanks a bunch
Old Oct 6, 2008 | 05:43 PM
Default RE: Tightening e-brake cable
There is an adjustment in the center console you will need a torxes bit to do it. I forget the size though I know it is pretty big.
Old Oct 6, 2008 | 06:17 PM
S70GLT's Avatar
Would that happen to be underneath the lever itself? I think I remember seeing a plastic insert that looks like it can be removed easily around there.
Thanks, I didn't realize it was that easy.
*D'oh!*
Old Oct 7, 2008 | 07:21 AM
Open the console lid then pull out the cover in the bottom and you should see the screw in the middle foward of the hole.
Old Oct 9, 2008 | 07:19 AM
S70GLT's Avatar
Thanks, I'll take a look today see what I can do.
Psaboic
Aug 28, 2018 04:02 PM
vjaneczko
Oct 9, 2011 04:29 PM
kapka42
Jun 29, 2011 01:25 PM
jcmartin
Jan 8, 2011 01:00 AM
wcthrel5
Mar 10, 2009 09:11 PM
