trim removal?
Small trim piece on the front fender: Held in place by two plastic rivets. Punching out the rivets from the inside would be ideal but you can gently force/pry it from the outside but it would scratch the paint job.
Longer trim pieces on the doors are held by a number of plastic tabs, but only one Torx screw actually keeps it in place. The Torx screw is close to the aft edge of the door; try to find it, remove it and the trim should slide aft and should be removed.
Some people use heat gun/hair drier to restore the original colour of the trim pieces, whereas others use Kiwi Shoe Dye.
I hope this helps. Wait for other helpful replies, too.
JPN
JPN
hovonogila
05-16-2019 02:28 AM
