Trying to get rear shock off
Old May 2, 2009 | 04:00 PM
dan2286's Avatar
Angry Trying to get rear shock off
I am trying to get my rear shock off. I got the top bolt fine, but the bottom is being very stubborn. The nut came off okay, but it is seized on the bolt/stud. I tried prying it, and smacking it with a sledge hammer. It will not budge.
Is there any trick to doing this?? I thought this would take like less than 10 min. to get off, but who knows how long it will take now.
This is 94 850 N/A with normal shocks, not the leveling kind.
Old May 2, 2009 | 06:45 PM
dan2286's Avatar
Never mind. PB Blaster and a torch did the trick.
Old May 2, 2009 | 06:46 PM
Glad you got it been there done that.
Old May 11, 2009 | 09:57 PM
GracelandII's Avatar
Did you jack up the suspension to compress the spring and get the tension off of it? I had a stripped nut on mine last week. Spent an hour under it with a die grinder, chisel and a 5 lb sledge hammer to get that bugger out. I should have known I was getting into trouble when I crawled under it and found the bump stops zip tied to the springs.
jared..mann
1998-2000 model year V70
Apr 20, 2013 04:33 PM
paul1149
Sep 6, 2012 11:20 AM
guysmilee
Mar 4, 2010 11:48 AM
axelm
Nov 21, 2008 10:24 AM
