Trying to run cell phone charger
Old Aug 22, 2010 | 06:23 AM
tjpeltier1's Avatar
Default Trying to run cell phone charger
Hi everyone!
I have a 1993 Volvo 850. I have been trying to rum my cell phone charger but it doesn't seem to work. Yes, I have tried other chargers and they are not workng either. And, yes, the cigarette lighter IS working. Any ideas??
Tammy
Old Aug 23, 2010 | 11:00 AM
vjaneczko's Avatar
If you look inside the lighter socket, you'll see a vertical strip of metal which makes contact with the lighter body. This strip provides the electricity to close the loop and cause the heating element to get hot. Your charger will also have a thin metal strip along the side. You'll have to lineup the two strips and make sure they contact each other when you insert the charger. Once you do that, it should be fine.
Another thing you can try is to gently twist the charger once its inserted until it stops. The theory is that the two strips will come into contact and they should be thick enough to allow current to pass through. My charger has a red light in it to easily show me when it’s getting power.
If you remove the charger, just make sure you remember the angle that it's inserted so you don’t have to lean over and peer down all the time.
Old Aug 23, 2010 | 02:31 PM
boxpin's Avatar
Some chargers are just flat out shaped wrong. If the Cig lighter is live and your charger is not working its just not making contact.
Old Aug 23, 2010 | 06:39 PM
fcpgroton's Avatar
Former Sponsor
+1
I would try a charger for a different device, like an ipod or something, and see if that works.
skying002
May 21, 2014 08:21 AM
NuForce
Aug 24, 2012 09:37 PM
Billy_V
Jul 22, 2012 07:05 AM
70down
Sep 14, 2011 06:11 PM
pbfurse
Apr 17, 2011 09:52 PM
