trying to track down a vac leak....oh what fun
Old 12-22-2009 | 03:34 AM
supernicguy's Avatar
Angry trying to track down a vac leak....oh what fun
So today while I was finishing my pcv replacement on my wagon I discovered a torn and I mean torn hose coming from my turbo into the intercooler, which would explain why i had such inconsistant boost....anyways after i got it all back together i went to start it and it started and died immediatly. After a few tries i got it to start and run but it was either a play with the throttle to keep it alive or it would rev to about 3500 rpms before i shut it off. my boost/vac gauge is showing that i have no vacuum and if i get it to stay alive long enbough to get it in gear, i have hardly any brakes. now my question is where would the most likely place to look for a vacuum leak be? and how big of a vac leak would it have to be to cause all those problems? thanks guys
--Nic
Old 12-22-2009 | 09:03 AM
boxpin's Avatar
Sounds like a little more than a vacuum leak. Are you sure you have all the turbo hoses attached? MAP sensor?. Check the idle control valve for a broken hose.
Old 12-22-2009 | 11:33 AM
fcpgroton's Avatar
Former Sponsor
That would be the largest vacuum leak ever. I would check all the intake hoses and the vacuum tree for leaks. Did you install a new manifold gasket when you did the PCV? Even if you did, I would take a look at the manifold too.
Old 12-22-2009 | 02:01 PM
just got done looking at it again, and for some reason the manifold didn't seat right. so now i have to pull it back off and see why....
Old 12-22-2009 | 02:45 PM
*update* there's a bracket on one of the lower manifold bolts, somehow i let it get smashed between the block and the manifold instead of being on the outside of the manifold. (i feel like a dumbass) anyways that it explains why it didn't seat right, got it fixed, all is well
Sipavicius
10-21-2013 08:06 AM
kennedy759
04-23-2012 08:43 AM
Feffman
04-03-2011 01:47 PM
Feffman
12-30-2009 10:10 AM
Quick Reply: trying to track down a vac leak....oh what fun
