turbo cleaning?
Old Jul 18, 2007 | 03:12 AM
flamejet's Avatar
Default turbo cleaning?
was curious if there is a specific process to clean the turbo? i was lookin around the parts store, and didnt see any products - which, i thought was odd, considering theres 5 or 6 different ones for ... oil , gas , coolant, trany leaks, etc...
is it even NECESSARY to clean a turbo?
96 854 turbo
95 854 T-5R
Old Jul 18, 2007 | 05:33 AM
JPN's Avatar
JPN
Default RE: turbo cleaning?
Hello Flamejet,
Greetings from Narita, Japan.
No, a turbocharger does not usually need cleaning. The turbine/compressor assembly is turning at approx 160,000-200,000 RPM, and there is not much of a chance for anything to accumulate as the centrifugal force is enormous and anything that comes into contact (other than hot exhaust/intake air which should have been cleaned by the air filter) will be thrown outward. However, it is recommended that you do after-idle for a few minutes (the owner's manual specifies 1-minute after hard driving), I personally let it idle for 3-5 minutes in summer, 2-3 minutes in winter. Also, the most important protection you can give a turbocharger is engine oil management. If the oil degrades due to neglected maintenance or if the oil level drops too low, the turbine/compressor bearings will be burnt. For a turbocharged engine, synthetic/synthetic-blend oil is highly recommended.
In the case of jet-powered airplanes, there is a cleaning process called "field cleaning". This is nothing more than spraying the compressor with a stream of water with the engine at idle.
I hope I've answered your question. If not, other members can help you understand better.
Good day,
JPN
Old Jul 18, 2007 | 11:33 PM
flamejet's Avatar
you answered it, and added to it thank you
Old Jul 19, 2007 | 02:17 AM
JPN's Avatar
JPN
My pleasure!
JPN
Old Jul 19, 2007 | 06:59 AM
axelm's Avatar
Great answer JPN!
mudpie
May 18, 2015 10:40 AM
shoeboxOH
2001-2013 model year V70
Oct 1, 2013 09:21 AM
shwebo
Feb 24, 2012 12:39 PM
proudmonkey
Jul 21, 2005 10:01 PM
Ocotillo
Mar 28, 2005 04:02 AM
