Turbo cleaning
Old Apr 27, 2015 | 09:54 PM
mudpie's Avatar
Default Turbo cleaning
Found a T5 in a junk yard and grabbed a 16t, fairly cheap. The impeller is a mess though. Any thoughts on how to clean this up? Carb cleaner does just slightly more than absolutely nothing.
Old Apr 27, 2015 | 10:15 PM
Look to see if you can find Wynns turbo cleaner (popular with the diesel crowd). I did see a post on a VW/Audi board suggesting "Mr Muscle" aka oven cleaner (try searching for "mr. muscle turbo clean". The post suggested scraping off what you can with a razor or wire brush then trying the cleaners to see if you can soak off the coking.
Old Apr 28, 2015 | 10:02 AM
boxpin's Avatar
There are two reasons that looks the way it does.
1. Turbo oil seal is shot
2. Engine was passing oil through the exhaust.
Since you dont know if it is or is not the turbo oil seal you should consider rebuilding it. That will give you piece of mind. Once apart you can bead blast that to look brand new. Some have used diesel fuel to remove gunk. You will need to clean out the oil ring groove. When doing this you need to take the up most care as to not scrape or damage the surface it rides in as well as well as the surface in the CHRA. When done it should be a great turbo.
Seal area.
After bead blasting.
Old Apr 30, 2015 | 12:05 PM
mudpie's Avatar
Originally Posted by boxpin
...you should consider rebuilding it. That will give you piece of mind.
That's pretty much the conclusion I came to. Since it's used, I know nothing about it.
Any advice, from anybody, on....
Where to get a rebuild kit? I know they're all over the internet, and eBay, but I'm not sure about the quality of something that's being drop-shipped from China. I suppose everything is made in China these days though.
Also, I've looked at a few websites that mentioned caution with regard to marking orientation to maintain balance of the assembly when re-installed. And I've seen mention of some turbos having reverse threads.
I've never had a turbo apart, so any input is appreciated.
Thanks
Old Apr 30, 2015 | 02:55 PM
boxpin's Avatar
There are two kits. OEM Mistubishi and China. China costs less. You can get either on ebay or other sites. Obviously quality is a factor so nobody can make the decision for you. Both will work.
Mark the shaft, compressor wheel and bolt. Dissemble and rebuild then reassemble matching your marks back up.
Old May 6, 2015 | 11:12 AM
mudpie's Avatar
Thanks. I appreciate the help
Old May 18, 2015 | 10:40 AM
jmh033089's Avatar
I just got an oem on ebay for like $85, I would not trust anything else because it is my dd
shoeboxOH
2001-2013 model year V70
Oct 1, 2013 09:21 AM
shwebo
Feb 24, 2012 12:39 PM
flamejet
Jul 19, 2007 06:59 AM
proudmonkey
Jul 21, 2005 10:01 PM
Ocotillo
Mar 28, 2005 04:02 AM
