Turbo idle control vale = EGR??
Old Sep 30, 2009 | 06:24 PM
porlagran's Avatar
Default Turbo idle control vale = EGR??
Is the EGR valve the same than the tubo idle control valve??
Old Sep 30, 2009 | 07:12 PM
No it is not.
Old Sep 30, 2009 | 08:33 PM
JPN's Avatar
JPN
Turbo Idle Control Valve: I believe you are referring to the wastegate/boost control valve. It is there to prevent over-boosting by relieving excessive pressure.
EGR Valve: Exhaust Gas Recirculation. It allows some portions of the exhaust gas to get drawn into the intake side to lower the combustion temperature in order to reduce the amount of NOx. It also allows a little portion of unburned fuel to get another chance to get combusted. The latter purpose, however, seems to have disappeared from modern textbooks.
JPN
Old Oct 1, 2009 | 12:25 PM
porlagran's Avatar
Thanks, I was looking on the IPD webpage and I couldnt find the EGR valve for the 850 models...
Old Oct 2, 2009 | 06:41 PM
Did you try FCPgroton.com?
rspi
Oct 12, 2011 06:49 PM
91shelby
Apr 29, 2011 01:04 PM
VTBricked
Dec 30, 2009 09:11 PM
Erich73
May 19, 2009 11:40 PM
burnferris
Feb 8, 2009 04:43 PM
