Turbocharger interchange 15G->16T: what's needed?
Old Dec 20, 2011 | 09:35 AM
chax's Avatar
Default Turbocharger interchange 15G->16T: what's needed?
Would replacing a TD04HL-15G CHRA with a -16T CHRA be a straight-out swap, or would other modifications, such as ECU exchange, be necessary? If so, how's that done? Thanks.
Old Dec 20, 2011 | 11:21 AM
boxpin's Avatar
Bolt in.
There is a distinct possibility that the water and oil ports my be in different spots. A visual inspection should remove any doubt but physically, it will mount right in the existing turbo exhaust housing.
Old Dec 20, 2011 | 11:20 PM
If it's a '94 or '95 you might need to change the flange on the end of the exhaust down tube off the turbo. The 94's and 5s used a conical fitting while the others used a straight or angled outlet.
Old Dec 20, 2011 | 11:50 PM
chax's Avatar
Default Sorry:
I should have specified: if I DO make the change, I'd just swap out the CHRA's. (Added CHRA info to initial comments on 12/21)
Old Dec 21, 2011 | 05:00 PM
boxpin's Avatar
You do not need to change the flange.
The Mitsubishi TD04 turbo housings are all the same on the turbo side. The exhaust housing outlet shapes can be different. You can leave your exhaust housing on the car and make the swap or take it out of the car, swap it then put it back in. Take notice when you remove the housing for a little pin that helps you keep the turbo clocked correctly.
If you have any specific questions PM me. Done this several times.
rspi
Mar 9, 2016 08:17 AM
Chrispy_T
Jun 9, 2013 12:35 AM
jessica
Jul 6, 2010 12:53 AM
olegs70glt
Jun 15, 2007 01:36 PM
anubyss
Jan 1, 2006 06:29 PM
