Turn signal intermittent
Old Nov 27, 2011 | 04:01 PM
jonwoolf's Avatar
Default Turn signal intermittent
Hi- My 1995 850 has this annoying habit- about 40% of the time the turn signal will stop flashing and just stay on solid. It happens on both sides. Hazards work fine. As usual, an intermittent fault like this is harder to fix than a totally broken one. I can't find the flasher relay to replace in case it is old and sticky (like me). Any clues??
Old Nov 27, 2011 | 05:50 PM
I don't have a solution, only the same problem. It's been on and off for about a year now. Like to see if anyone else chimes in. Hasn't happened enough for me to dig into it but it is annoying when it does happen.
Where is it located?
Old Nov 27, 2011 | 06:43 PM
On my 960 the flasher button was also the control. That is likely it. When you pull it out of the dash it's about 6" long.
Old Nov 27, 2011 | 08:00 PM
Would you like to use my bi-focals
zinko
2001-2013 model year V70
Jan 9, 2016 10:09 AM
manyguns
Jun 21, 2013 07:54 PM
DavePeeb
May 6, 2010 08:11 PM
