Intermittent Turn Signal Problem
Old Jun 15, 2013 | 08:34 PM
manyguns's Avatar
Default Intermittent Turn Signal Problem
2000 S40 Turbo. The turn signals will stop working intermittently every once in a while. Sometimes after you shut the car off for a while, they will start working again. They seems to be no pattern to it. All I have done is changed the fuse, although it wasn't blown. Has anyone else had a similar problem? Could it be a flasher going bad? When they stop working, not even the little arrows on the dash will light up . Where is the flasher on this car?
Thanks, Tom
Old Jun 21, 2013 | 07:54 PM
go-part's Avatar
Former Sponsor
Sounds like you may have to replace the turn signal switch.
zinko
2001-2013 model year V70
Jan 9, 2016 10:09 AM
jonwoolf
Nov 27, 2011 08:00 PM
DavePeeb
May 6, 2010 08:11 PM
