Turn signal screwed up
Old May 29, 2008 | 12:20 PM
jmana's Avatar
Default Turn signal screwed up
I replaced all the bent up front end parts on my 850 yesterday and now the right turn signal is acting wierd. With the headlights off, it works fine, but with the parking lights or headlights on both the front and rear lamp are lit solid, even without the turn signal being on, and turning the signal on does nothing, they just stay lit solid. I don't see how I could have screwed up the wiring, I mean it's just a harness for the headlight, and one for the turn signal for each side. And the wirirng wasn't messed up from the wreck either because the lamps worked fine before I took the body pieces off. Anyone have any ideas?
Old May 29, 2008 | 12:37 PM
Ozark Lee's Avatar
Default RE: Turn signal screwed up
Check the bulb, it may not be in the socket correctly causing a short between the turn signal and the parking light.
...Lee
Old May 29, 2008 | 06:21 PM
Check the wiring sounds like a wire is shorting out.
Old May 29, 2008 | 07:08 PM
Volgrrr's Avatar
ORIGINAL: jmana
Faults on a 12 volt DC system that use the chassis and motor as a return path to complete many of the circuits can be a real PITA. If the wiring is not 100% (e.g. poor/loose connections, wires not making good contact in a terminal, poor compression/soldered joints, conductor broken within plastic insulation, incorrect wiring etc.), direct current (DC) will try and find a way to complete its own circuit, and that sometimes means finding a continuous electrical path (i.e. backfeeding) through other items such as globes, etc. resulting in very confusing symptoms to try and troubleshoot.
You've just got to be patient, establish where each wire is supposed to go/terminate and ensure that's where the wire does go/terminate, check the conductor for continuity, and also thoroughly check each connection is solid. It is amazing how many connections that look quite O.K. are, in actual fact, making a poor connection or none at all.
Give me good old AC anyday.
Old May 30, 2008 | 08:42 AM
Psaboic's Avatar
Agreed....Check the bulb, then the wiring for shorts. Also check the grounds. I'll bet its something easy.
suckonthiscaravan
Dec 5, 2018 03:19 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
stook
Jun 21, 2005 06:24 PM
volvobacon
Apr 20, 2005 02:04 AM
