Unknown problem??Help
Old Apr 11, 2009 | 02:52 PM
fast850r's Avatar
Exclamation Unknown problem??Help
My wife was coming home from work this afternoon, and said the car would not go over 20mph. Oil was just changed a couple weeks ago. Oil level is fine, tranny fluid is at proper level. I can't seem to find anything. It is also raining here.
Anyone have any ideas or same issue?
Thanks
Old Apr 11, 2009 | 03:18 PM
Turbo?
If so did an intercooler hose blow off?
Old Apr 12, 2009 | 08:22 AM
fast850r's Avatar
yes it is a turbo. where should I look for disconnected hoses?
Old Apr 12, 2009 | 08:29 AM
At the top of the turbo,top of the intercooler and bottom of the intercooler. Also make sure the one going into the throttle body didn't blow out.
I had mine blow out at the wrong time once.
Old Apr 12, 2009 | 09:30 AM
cj351stang's Avatar
I've blown one at the throttle body also. Think that may be the weakest spot in the system. You should be able to hear air leaking while under boost if you have a leak after the turbo.
If there's a leak before the turbo (between turbo and air meter) it could also be your problem.
Old Apr 14, 2009 | 09:39 AM
fast850r's Avatar
Smile
well, turns out it was the large 90degree hose at the top of the radiator that connects to the air pipe that runs to the throttle body. Blew a hole right in it! Of course, need to get from dealer, but easy fix. Thanks all.
Old Apr 14, 2009 | 10:13 AM
Somthngfrce's Avatar
Wow, easy diagnose and Fix......... Good Luck!
Old Apr 14, 2009 | 08:43 PM
Glad you found it.
jonnybuckets
Oct 26, 2011 06:46 PM
alzdream
Jan 11, 2008 06:35 PM
J Telectro
Aug 17, 2007 05:48 AM
paul_con
Mar 14, 2007 05:33 PM
Volvo2001
Aug 24, 2006 09:52 PM
