Using Seafoam before Oil Change?
Old Aug 30, 2012 | 11:32 PM
Marvin Lee's Avatar
Default Using Seafoam before Oil Change?
I have an 1994 Volvo 850 and will be changing the oils soon. I just bought this car for $500 buck cuz the other owner could not get it started. Well, I did, it's a great car. Anyway has anybody used Seafoam in there oil prior to oil changes. I want to clean this sucker out good before I do oil, plugs. Etc. any input would be great. It a Non- Turbo.
Old Aug 31, 2012 | 08:05 AM
boxpin's Avatar
I have to help clear some tapping valves. Its ok to use but I would not drive around on it. Get the engine warm and put it in. Run the engine for a few minutes then let it sit overnight. The next day, start it again and get it to temp. Shut it off and change the oil.
Old Aug 31, 2012 | 09:49 AM
kkarasch's Avatar
I have heard using a quart of tranny fluid also provides similiar results.
Old Aug 31, 2012 | 10:50 AM
slimflex2's Avatar
true but not drive around with tranny fluid in your engine.
Old Aug 31, 2012 | 10:17 PM
Msuperbauer's Avatar
I did the seafoam thing in the oil ,worked great. I work about 6 miles from my work and I added the seafoam to the oil, drove to work and home a couple days,, then changed the oil. I'd recommend it!
Old Aug 31, 2012 | 10:21 PM
I've used tranny fluid before doing a change and I do drive around with it in there. It's basically just a quart of 10 weight oil it just has more detergents in it than motor oil. Seafoam works great and you can drive on it ... dedicated engine flush --> follow the directions on the can !!
Attached Thumbnails Using Seafoam before Oil Change?-seafoam-motor-treatment.jpg   Using Seafoam before Oil Change?-engine-flush-crc.jpg
Old Aug 31, 2012 | 10:31 PM
Marvin Lee's Avatar
Ok thanks I will do that. I'm going to just idle it for a bit, then let it rest and change it the next day. I thought I was going to just buy and sell this car, but it runs pretty good as is after I got it running, and for 500 bucks. I'll just keep it for a while.
jessicat
Mar 8, 2010 11:19 PM
benelisha
Nov 21, 2008 11:45 PM
megatrack
Sep 11, 2007 02:29 PM
moffett
Jan 26, 2006 09:43 PM
Ocotillo
Mar 31, 2005 09:25 PM
