Vibration Fixed!
Old Apr 25, 2007 | 01:37 AM
BriGuy's Avatar
Default Vibration Fixed!
A week or two ago I posted looking for info on a vibration that happened at freeway speeds when I stepped on the gas - no gas, no vibration. Turned out to be the passneger side driveshaft. The inner CV (the one closest to the bearing carrier) was bad and allowed the shaft to wiggle around when under power. Replaced it with a reman'ed unit and all is well again.
Old Apr 25, 2007 | 03:05 AM
RedTurbo850's Avatar
Default RE: Vibration Fixed!
Great!
Old Jun 24, 2007 | 09:43 AM
green850's Avatar
do you think that would have any relation to my vibration i get when i use the brake?
my pads are fine so it's either the tranny not down shifting or maybe something like your problem
any input would be apreciated
Old Jun 24, 2007 | 10:41 AM
ORIGINAL: green850
do you think that would have any relation to my vibration i get when i use the break?
Yours sounds like Warped rotors.
Old Jun 25, 2007 | 10:16 AM
green850's Avatar
how would i tell?
Old Jun 25, 2007 | 10:17 AM
green850's Avatar
also it's not everytime i use the brake, it basically does it more when it's warmed up or hot
Old Jun 25, 2007 | 05:39 PM
Any vibration while braking is warped rotors.
Vibration in the brake pedal is the rears.
Vibration in the steering wheel is the fronts.
Old Jun 27, 2007 | 05:05 PM
green850's Avatar
i'd have to dissagree, the transmission getting hung up could also cause that, which i think is my problem
Old Jun 27, 2007 | 05:57 PM
ORIGINAL: green850
Then the car would also do it coasting to a stop.
If the transmission was hanging up while stopping then the RPM's would drop below idle numbers while slowing down then would raise back up.
Old Jun 27, 2007 | 08:31 PM
JAKESTERS's Avatar
I agree with Tech on this one , rotors. You can get them turned ,but for 38.00 each you can get new ones from XYZ..
Old Jun 28, 2007 | 08:41 AM
Psaboic's Avatar
Agree....rotors. Also, tech is correct in diagnosing if it is the front or rear rotors. It all depepnds on what vibrates when stopping. Usually when I replace rotors, I do them as a set of four.
ocean238
Apr 17, 2008 06:20 PM
Bender
May 13, 2006 11:28 AM
wavewright
Apr 23, 2005 12:57 PM
knight rider
Apr 14, 2005 12:07 AM
knight rider
Mar 29, 2005 07:33 PM
