Volvo 850 - ABS Fault Codes
Old Jun 10, 2009 | 06:19 PM
denver005's Avatar
Default Volvo 850 - ABS Fault Codes
What is the procedure to read ABS fault codes? Does it require a special scanner? I am thinking one can use the ODB II port inside the car to read the codes.
R
year:1996
Make/Model: Volvo 850 Turbo
Old Jun 10, 2009 | 07:58 PM
If it is a 94 or 95 you can do it from under the hood. 96 and 97 have to use a scanner to read the codes.
Old Jun 11, 2009 | 08:02 AM
bestharry's Avatar
It seems he has a 96...so YES, you need a special Volvo Tool to read the codes and clear them.
Wondering if you are not facing the very common ABS module failure on those year 850s?
The common symptoms would be - ABS and /or Tracs OFF lights staying ON intermittently and the speddometer migth also die once in a while.
v1lcins
May 20, 2022 10:53 AM
texasinger
Jul 22, 2011 12:38 PM
jeffwi850
Aug 16, 2007 08:29 PM
uncle
Nov 9, 2006 08:45 PM
