volvo 850 stereo
Old Jan 18, 2010 | 10:51 AM
TONY12340's Avatar
Default volvo 850 stereo
hi guys
just joined the forum after recently acquiring a volvo 850 "93model
great car but having trouble fitting an after market stereo.
iv located the factory amplifier and disconnected the connector.
are the wires for the speakers connected to this connector?
any help would be much appreciated...
many thanks
Old Jan 18, 2010 | 11:33 AM
Dah_jOkA's Avatar
What kind of aftermarket stereo did you buy? did you buy the harness for the stereo as well?
Old Jan 18, 2010 | 12:50 PM
TONY12340's Avatar
iv got the pc2-19-4 harness.
like this one
http://cgi.ebay.co.uk/Volvo-Car-CD-I...item5d276181f1
is it simply jus plug and play??
Old Jan 18, 2010 | 01:13 PM
Dah_jOkA's Avatar
it pretty much is, I installed a after market stereo into mine within 20 mins, Just match the wires by color, and make sure you tape up the wires with electrical tape.
least that how it was for me.
Old Jan 18, 2010 | 02:52 PM
boxpin's Avatar
Are you using or not using the factory amp?
Old Jan 18, 2010 | 09:39 PM
matt01's Avatar
i have the same question, i also bought the harness adapter and connected it directly like there was no amp., i want to use my stock amp, what do you have to do to your amp in order for all of your speakers to work?
Old Jan 18, 2010 | 10:14 PM
boxpin's Avatar
The harness should work. The amp is a great design where is it just a pass through. You end up with the same harness whether you use the factory amp or not.
Old Jan 18, 2010 | 10:15 PM
matt01's Avatar
but if you just attach the harness not all of your speakers are going to work.
Old Jan 30, 2010 | 03:00 PM
TONY12340's Avatar
hello guys...havnt been around much but to update i have music in the car!!
woo hoo
this is the wiring harness i used
i located the amp and have removed id. attached the wiring loom to the end that was plugged into the amp.
works a treat!
thanks for your replies
fairleekind
2001-2013 model year XC70
Feb 23, 2013 08:33 PM
Jesse94
Dec 26, 2011 07:11 PM
nkhlystov
Dec 14, 2010 01:30 AM
Sipheren
Aug 5, 2009 11:29 PM
USSEnterprise
Oct 1, 2006 10:19 PM
