Volvo 850 SC-801 Stereo
Old Aug 5, 2009 | 08:13 AM
Sipheren's Avatar
Default Volvo 850 SC-801 Stereo
Hi,
I am just after some help with the stereo in my 850, I want to connect an after market amp to it to power a subwoofer but on the back on the unit all I see is a DIN plug with AMP written under it.
I have searched and found a DIN connector for it and 2 female RCA plugs, I want to connect them together but I need to know which pins are what on the DIN plug.
I have been searching for a wire diagram but can not find one, I would really appreciate it if someone could show me where to find one or tell me what the points are.
Thanks
Old Aug 5, 2009 | 09:14 AM
boxpin's Avatar
Dont even bother, get an amp that has High Level inputs. Tap onto your rear speaker outputs. Done.
Old Aug 5, 2009 | 03:50 PM
Sipheren's Avatar
I hate high level input, sounds crap. If no one knows I will just test each one and find out myself, just thought someone would know....
Old Aug 5, 2009 | 11:06 PM
boxpin's Avatar
Sounds crappy for higher frequencies, agreed. Bass is a different matter and not subject to the same sound laws. Why would you be worried about the sound of high level inputs if you are running the stock stereo? Your sound will only be as good as that stereo, no better.
(17 years experience in car audio, Car Installation Manager of three major audio retail stores [Federated, TheGoodGuys, Mobilworks], IASCA certified judge and MECP certified...I know my stuff) :-)
There are very few prongs on the Amp output and should be easy to locate, especially if you open the radio. If you have any trouble let me know and I will look at mine. I have a couple lying around.
Old Aug 5, 2009 | 11:29 PM
Sipheren's Avatar
I found what I was after from another forum so all is good.
The stock sound system is fine, and the line output will send quality sound to my own amp which will determine the quality of the bass.
Thanks anyway.
rkos1
Nov 24, 2011 06:11 AM
M.gabassi
Dec 9, 2008 08:50 PM
OverTheTop
Feb 3, 2008 10:23 AM
Richard74
Aug 7, 2006 02:12 AM
Gonzo
May 20, 2005 02:02 PM
