Volvo 850R led headlight bulb
Old Nov 9, 2018 | 07:20 PM
860ARE's Avatar
Default Volvo 850R led headlight bulb
Anyone ever tried the led bulbs on amazon? Im thinkIng about the Beamtech hb4 bulbs. Good reviews and only 37$ . Anyone use them?
Old Dec 3, 2020 | 12:47 PM
srcerveza's Avatar
Did you ever purchase the LED bulbs? If so, what was your result?
Old Dec 3, 2020 | 03:28 PM
main issue with LED bulbs is they have a different resistance from traditional halogens and will likely set off the bulb out indicator.
Old Dec 3, 2020 | 03:30 PM
srcerveza's Avatar
That makes sense. Would be annoying to have the warning light on all of the time.
Also, appears that this is a solution for low beam only and no high beam.
Old Dec 3, 2020 | 03:35 PM
you may want to google around to see if there's a hack to keep the warning light from coming on (lol short of removing the bulb from the back of the cluster)
Old Dec 3, 2020 | 03:47 PM
srcerveza's Avatar
Good idea. I just wondered what 860ARE's experience was with the bulb, if it even made sense to try.
Saw somewhere where different bulbs were a bear to get to fit because it was so tight.
Old Dec 4, 2020 | 11:19 AM
860ARE's Avatar
The bulbs are still in there working fine. Warning light bulb does not come on. Although to install I had to remove the headlight and remove the lens in the front and do some custom work to make them fit. Which involves cutting some housing. And yes I only did the low beam for now. Cheers
Old Dec 4, 2020 | 01:40 PM
srcerveza's Avatar
Thanks for the follow-up information. Glad it worked out well. If I proceed, I may DM you.
Old Dec 4, 2020 | 03:24 PM
860ARE's Avatar
Roger that.. good luck
rlerner
Jan 5, 2020 03:39 AM
fjgj99
Aug 9, 2018 12:53 PM
RA082324
Jul 7, 2016 03:36 PM
FuzzyLogic
Feb 1, 2014 01:23 AM
NCdad
Oct 22, 2011 12:21 AM
