weird A/C works well if car is cool..
Old Jul 18, 2010 | 02:36 PM
850_96's Avatar
Default weird A/C works well if car is cool..
Ok so my A/C seems to work if the car is parked in the shade before driving or if the temp. is in the 80s and below. Here in NY its been 90+. Today when i first turned it on it worked great ( it was parked in the shade). I drove about 15miles and stopped at a gas station. Turned the car off and about less then 5mins later i turn it back on, the A/C wasnt working that well as before. So after that i figured it got hot so i just went to the supermarket with the windows down. But after i went to the market i decided to try it again. It worked! The car was not in the shade though. What i did was i put the blower on level 2 and it seemed to slowly get colder and colder.. so idk its a weird a/c LOL
Old Jul 18, 2010 | 06:45 PM
Drive it till it stops working. When it stops working check for power at the wire on the compressor. If you have power there and the compressor is not working it needs a reshim.
Old Jul 19, 2010 | 09:55 AM
850_96's Avatar
yeah, i was thinking of bringing it back to the shop? do you think its that evaporator or whatever that is?
Old Jul 19, 2010 | 10:02 AM
vjaneczko's Avatar
What did the shop do to the car?
The evap is located inside the car and releases the cool air into the cabin, but it's not a mechanical device. It's like a heater core - only for cold! If there's a problem with it, it'll have a hole in it and can cause a mist to fill the cabin when running the A/C.
Old Jul 19, 2010 | 05:34 PM
850_96's Avatar
oh ok. is this expenisve to replace?
Old Jul 19, 2010 | 06:27 PM
vjaneczko's Avatar
If it is the problem, the evap isn't too bad if you do it yourself;
http://www.fcpgroton.com/product-exe...category_id/66
A shop will charge about a grand to do it.
You can search for a post (here or over at MVS) that reviews the repair procedure. It looks easy, just time-consuming.
Old Jul 19, 2010 | 08:02 PM
If the evap was bad the A/C would not work at all or would work cold for a few days or weeks. Then get warmer and warmer till it stops working over time.
What you explain sounds like the compressor clutch needs a reshim.
Old Jul 20, 2010 | 09:13 AM
850_96's Avatar
ok, yeah b/c it works just under certain conditins and if the blower is on a low number ( usually 2/3). ill have someone look at it again
Old Jul 20, 2010 | 06:54 PM
You can also measure the clutch gap with a feeler gauge. Max gap it .025 I think yours will be around .035. That is to much.
Old Jul 20, 2010 | 09:29 PM
850_96's Avatar
ok thanks!
blackbrick
2001-2013 model year V70
Aug 14, 2014 07:11 PM
swiftjustice44
Oct 25, 2012 06:32 AM
mstrplmber
Jun 26, 2010 04:10 PM
Deacon1971
Jun 8, 2010 12:06 AM
