What is wrong with this manual?
Old Mar 14, 2014 | 12:45 PM
Default What is wrong with this manual?
A guy I met has these symptoms with his 5 speed 850:
Difficult to get into gear, lurches when backing up, & won't roll freely when clutch is fully depressed. Any ideas?
Old Mar 14, 2014 | 03:11 PM
Fogducker's Avatar
Sounds like it either needs a new clutch or you might get away with a clutch adjustment Robert.
My 5 speed wagon had similar issues and a new clutch solved the problems.. ;-)
Old Mar 14, 2014 | 03:43 PM
John Arsenault's Avatar
Unless its slipping I would lead towards the hydraulics, Hydraulics in the clutch are much like your brakes. A little air in the system and your clutch won't fully disengage. Could just be an adjustment needed like fod said. That can be done pretty easy from under the car where the slave cylinder pushes the clutch arm, you would want to adjust it so that it pushed the arm a little further. If thats the scenario a new clutch would fix the problem to because it would need to be adjust after anyway. So just to be clear here ...adjust it and see how it is then.
Old Mar 14, 2014 | 11:16 PM
boxpin's Avatar
I think they are on the right track, bleed the system first.
discodave
Jan 20, 2012 09:28 PM
Jimal
Dec 12, 2008 08:05 PM
J Telectro
Jan 10, 2007 09:25 AM
michaelmorris
Jan 24, 2006 10:52 AM
