What's the best way to confirm a bad ball joint?
Old Sep 17, 2010 | 09:48 AM
brianb's Avatar
Default What's the best way to confirm a bad ball joint?
Hey guys...I'm hearing a popping noise coming from the passenger side front wheel when turning. I willing to bet it's my ball joint but, it there a good way to confirm this? Thanx
Old Sep 18, 2010 | 08:28 PM
gdog's Avatar
I can tell you how we used to do it..
Car up on hoist (suspension unloaded), take a big slip-joint (aka water pump) pliers and try to compress the ball joint itself; should see virtually no movement (up and down).
This assumes the boot's not torn too, obviously.
BTW: typically ball joints don't pop; they clunk, when worn. Usually they don't make any noise at all, unless the boot's torn and the joint starts to seize up from rust.
If it is popping/clicking, I would suspect a CV joint and/or sway bar links as more likely failure point. You can temporarily remove your sway bar links to help isolate it..
Old Sep 20, 2010 | 03:02 PM
brianb's Avatar
Thanx Gdog...Oddly enough, it hasn't made that sound since I posted this (about 70 miles driven on it this weekend).
dpvovo
Feb 18, 2019 07:41 PM
PetarYanev
Aug 28, 2013 09:36 PM
karutunian
Mar 15, 2010 05:19 PM
keaunym
Feb 27, 2009 08:42 PM
