window issue
Old Nov 9, 2009 | 09:06 PM
cjaama's Avatar
Default window issue
i just went and looked at a '96 850 and the driver's window wouldn't roll down. the car has been unregistered and off the road for 7 or 8 months and the man selling the car told me it worked before. it makes a clicking noise like it wants to go down, but nothing happens.
what are the chances it's the window regulator? is there any way around spending at least $200 getting it fixed.
Old Nov 9, 2009 | 10:25 PM
Somthngfrce's Avatar
You could just do it your self.....also check the switches on the center stack.
Old Nov 9, 2009 | 10:38 PM
boxpin's Avatar
If its clicking the switches are probably working fine. Do you hear the motor running with that clicking noise? If you do need a regulator I have one.
Old Nov 10, 2009 | 08:10 AM
cjaama's Avatar
you hear a click from the door, but no motor running.
you have a regulator? used? how much do you want for it?
Old Nov 11, 2009 | 10:46 AM
boxpin's Avatar
Yes I do have one, used, from a 95 T-5R ...PM me
Old Nov 21, 2009 | 07:35 PM
cjaama's Avatar
i got a new/used window regulator in the mail (thanks boxpin) and attempted to replace it today. turns out the motor works fine, but it only works in one direction, up. therefore i believe it is the switch and will likely pull the switch and use some electric cleaner to spray it and hopefully that will work for a while.
however, the problem is that when i did roll the window back up, i had to guide it with my hands to keep it from coming out of the track. do i have to open it back up and replace the rollers?
i also could not get the regulator unit out of the door once all the bolts were removed. is there any trick to that?
Old Nov 21, 2009 | 07:44 PM
You have to be able to move the regulator up and down to work it out of the door.
Old Nov 21, 2009 | 11:16 PM
cjaama's Avatar
but the only thing holding it in is the bolts, it should just shake out from there?
Old Nov 22, 2009 | 05:04 AM
Not sure but let me see if I have an extra set of switches that work well...
Old Nov 22, 2009 | 05:33 AM
Do you have the window out?
Old Nov 22, 2009 | 06:34 AM
But one of the gears on the regulator is bigger than the hole it comes out of. So basically you have to tilt it and then move it and have the gear swing outside the hole and remove it all.
Old Nov 22, 2009 | 10:04 AM
cjaama's Avatar
The window is not currently out. I put everything back the way it was so I could continue driving.
Old Dec 7, 2009 | 01:00 PM
cjaama's Avatar
after three straight weekends, i finally have a driver's window that operates properly.
after i attempted to replace the regulator, which i thought was the problem, but ended up being fine, i decided it was the switch. i've read that spraying the switch with some contact cleaner can temporarily fix the problem, but i wanted a permanent solution. i replaced it with a used switch off ebay. the one that was in the car had obviously been submurged in soda.
my window was going up crooked as well, which after some searching, i discovered that it was because a vertical track had been broken. here is the link i used:
http://www.matthewsvolvosite.com/for...108135#p108135
very relieved to finally have it fixed.
Old Dec 11, 2009 | 08:31 PM
Glad all is fine now!
Old Dec 12, 2009 | 10:28 AM
cjaama's Avatar
thanks, i was elated to have it fixed!
Old Dec 12, 2009 | 10:41 AM
I bet!!!!
Old Apr 20, 2010 | 06:50 PM
  #17
kapka42's Avatar
Im currently havin teh same problem in my 95 850 glt. The switch makes a clicking noise, and the motor runs when you close it, but not open, i tried spraying some electric cleaner in there but it didnt work
Old Apr 21, 2010 | 08:07 AM
  #18
cjaama's Avatar
i ended up replacing my switch unit with a used one off ebay and that worked for me. find a used unit that's in working condition and try that out. good luck.
Old Apr 23, 2010 | 04:33 PM
  #19
I had a 960 switch that had a contact problem once and I took the thing apart. Once apart I found that there was some contact studs in there that had what looked like carbon build up on them. I took a small metal file and cleaned the contacts off and the switch worked fine. I also purchased a switch from iPd that worked great.
Old Apr 29, 2010 | 01:26 AM
  #20
kapka42's Avatar
i ended up takin my whole console apart, and spraying inside the broken switch with some electric socket cleaner, after playing with the switch for a while it worked
MIK911
Feb 9, 2017 10:08 AM
reecesp1eces
Feb 2, 2014 08:44 PM
steved
Dec 20, 2008 05:37 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
