Window Switch Ball Bearings
Old Jun 4, 2012 | 08:47 PM
LandonJBennett's Avatar
Default Window Switch Ball Bearings
My driver side window was not rolling up so i decided to take apart the window switch and clean the connections. However, in the process I lost the ball bearings inside the middle of the car while getting the switch off. Does anyone know where i can buy more ball bearings? Are they generic ball bearings? Any help would be appreciated.
Old Jun 4, 2012 | 09:34 PM
You'll probably have to go get another switch assembly.
Old Jun 4, 2012 | 11:09 PM
What he (RSPI) said
Old Oct 9, 2012 | 04:09 AM
Ball Bearing's Avatar
You come the right placeJust ask which type of ball bearings you need?They are not generic ball bearings.If you need single row ball bearing,check it.And more deep groove bearing.
Old Oct 9, 2012 | 04:30 PM
Lynn_B's Avatar
I haven't seen inside a Volvo window switch, but if they're like other brands' switches, you might go to a sporting goods store (or Wal-Mart's sporting goods section) and buy a small pack of BBs for a BB gun. The initials BB stand for "ball bearing" in the first place. The ball bearings in your switch are used for the fulcrum point, right? If so BBs might be close enough to the right size to work, and you get several hundred spares for cheap.
Just a thought. Hope it helps.
Lynn B.
dpvovo
Feb 18, 2019 07:41 PM
torontos80t62000
Oct 13, 2013 09:07 AM
bennyd20
Sep 23, 2011 07:34 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
