Won't Start
Old Oct 26, 2006 | 07:59 PM
SDozier's Avatar
Default Won't Start
1995 850 Turbo
At work, I cranked (no problem) the car and went to another school approximately 1/2 mile away. Turned off the engine went inside and came out after approximately 30 minutes. Car would not turn over. Lights, etc. worked fine. Horn was loud. While I was inside, a heavy rain came and splashed water from the roof on top of my vehicle. Engine is dry (on top). Battery cable connections were clean (I scraped again just in case). No luck. Ideas? Did it get wet underneath with water splashing up from the concrete? It was not standing in water?
Any tips on what to look for?
SD
Old Oct 27, 2006 | 01:11 AM
MikeySq's Avatar
Default RE: Won't Start
does the starting motor click or make a sound at all?
could be:
starting motor
solenoid/relay for starting motor
PNP switch on tranny
other electrical issue
-Mike
Old Oct 27, 2006 | 01:13 AM
SDozier's Avatar
No sound at all. It must be the solenoid?
Old Oct 27, 2006 | 08:07 PM
MikeySq's Avatar
ORIGINAL: SDozier
it could be the PNP switch, that waould lock out the solenoid from energizing
is should be easy to test the solenoid once you have access to it.
Old Oct 27, 2006 | 09:30 PM
SDozier's Avatar
I believe it is the PNP switch. It is at the dealer as I write. Will keep you posted.
SD
Gustav
Nov 11, 2017 01:01 PM
volvoralph
Jul 19, 2016 04:19 PM
hokiedave
May 4, 2009 12:37 PM
exotek
Nov 11, 2008 09:32 AM
