Yellow is dead!!! But now alive!
Well more drama to add to my bad luck and this motor rebuild.
After Someone trying to help out (Person nameless) on getting my pistons cleaned up before putting it all back together. They put them in a bucket of solution for cleaning parts. I had said I wanted to remove the bearings out of the rods so nothing would happen from the solution.They said no they would be fine. Well yesterday after removing them from the bucket to finish cleaning them off. What do I find you ask?
The cleaner has eaten the outer babet layer off the bearings! (F***!!!) Now I am screwed I have been cutting every corner I could on this rebuild. I needed this car back asap and now it will be down for atleast another week now!!! But I am not paying for the new bearings they are buying the new bearings. If it had come to me having to buy them Yellow would have been down atleast 6 more months or so. This happened at a really bad time and I cannot afford to have to keep buying parts. If stuff like this keeps happening it will be parked for a while.
But tomorrow I will be working on it. The crank will go into the block. I am also going to finish cleaning the head and putting new valve seals in and lapping the valves.
Hopefully I can get something done tomorrow. I will update after getting home. I will have more pics as well.
Damn man, I wish I could help you out with this build. if there's anything you need that you have a hard time getting, I'll be more than happy to search the boneyards around here. granted, you wouldnt want to use used bearings, etc, but if it were a head or valves or something you could get by with, just let me know.
Today's progress was I got the crank in the block and 2 of the rods in and torqued.
Also got all the new valve seals in the head. I am hoping to have the motor fully together next weekend.
Here is today's pics.
Sorry about the crappy Black Berry pics.
But things are the other way again. Friday my boss ordered the bearings. But the parts guy dropped the ball and no bearings today hopefully tomorrow.
It just never ends!!!
Well I made some progress today on the motor.
Here is what I started with this morning.
After a few hours.
Then at about 5:00
And to top it all off I think I was running lean even though the wide band was saying I was running rich!! Maybe time for an upgrade on injectors!
Hopefully it will be running next Sunday.
After a few hours.
Then at about 5:00
Yes if I decide to race it again it will have a BIG oil cooler and racing oil in it.
Now I also need to find a set of white injectors for it. The wideband was saying rich all the time but have signs it was running lean.
