2008 C30 LED Bulb Conversion Questions?
Old May 17, 2022 | 07:10 AM
Hedge133's Avatar
Default 2008 C30 LED Bulb Conversion Questions?
HI All. I'm in the midst of changing my Exterior bulbs out with LED Bulbs. After I had done the first turn signal bulb, I got the hyper flash. If I remember correctly from one of my past Volvo's, the flasher unit was built in to the Hazard Switch. Is this also the case with my C30? Either way, has anyone figured out a way to do the turn signal bulbs without getting the hyper flash?
Old May 17, 2022 | 10:32 AM
Dingus1's Avatar
You can try and wire in resistors, "hyper flash eliminators", etc. Some bulbs are easiest left OE on Volvos.
RIN
Sep 10, 2021 07:31 AM
rcvolvo
Feb 9, 2021 10:11 AM
surfbros
Mar 12, 2012 09:27 PM
Tortuga
Oct 2, 2011 08:07 AM
j-velocity
Apr 14, 2010 07:56 PM
