Possible fuse missing?
Came into a used 2009 C30 in the winter time, and didnt think to ask about the AC. Its getting warmer, so when I tried to turn it on, it didnt blow cold air. It also doesnt feel like its engaging, (no change in power whatsoever when switched on).
I thought I would try checking the easiest option, if the AC compressor fuse was blown. It appears ok, however, when I checked fuse 5, the "Climate Element", it is missing. Is that normal? I havent been able to find any photos online with that fuse missing.
My next step would be to order the missing fuse and replace to see if that helps, but I wasnt sure if that would cause an issue if its not supposed to be there in the first place?
Thanks for any advice.
