Problem with signal of AM radio
Old May 4, 2014 | 02:26 AM
Banbury Volvo's Avatar
Default Problem with signal of AM radio
Hello all
I have a C30 (2010) and a problem has started with my radio. On FM the signal is great, no problems at all.....but on AM the signal appears to be affected by a loose wire, as when I drive and listen to AM the signal goes all over the place. I suspect the radio has two wires for aerials (one for FM and one for AM) just like any decent home stereo unit, but are the wires easy to get to, and is this something that a car novice could fix.
If not, am I looking at a large repair bill from a Volvo dealer?
Any help gratefully accepted......
Thanks
Banbury Volvo
Old May 4, 2014 | 10:38 AM
damien360's Avatar
2 problems cause this issue this first is the am antenna goes bad but that's is very rare. The second is the intergraded audio module (IAM) which is the CD player, goes bad on those cars causing problems with the FM radio. So it needs s new IAM and a software reload.
Old May 5, 2014 | 01:49 AM
Thanks Damien....
The CD player works perfectly, as does the FM radio, the problem only exists when I listen to AM. When the car is parked up, the signal is fine, but when I start to drive the signal is affected......If I had to guess I would say it is a loose wire somewhere that needs fixing.....is this possible (the loose wire that is)?
Old May 6, 2014 | 03:47 PM
deezy's Avatar
I had a very similar problem with my 09 (AM radio would sometimes work fine, other times not at all, but FM/CD/AUX/SAT all worked flawlessly). They ended up replacing the IAM (I had an aftermarket warranty so I was only out the $100 deductible). Hope this helps.
Old May 6, 2014 | 07:04 PM
damien360's Avatar
Yes the CD portion would be fine but because the cd player is a computer the problem lies in there
Old Jan 24, 2016 | 07:59 AM
Okidiver's Avatar
Mega bump here...my AM radio is dead on my '08 C30.1 and word is not worth the cost to troubleshoot/fix. Next oil change I'll bring it up and see if dealer has a quick/easy/cheap fix--if not, don't need no stinkin' AM...
JOEMAN
Jan 16, 2012 08:55 AM
rogereloco
Aug 27, 2008 12:05 AM
jktiffin
Jun 4, 2006 02:41 PM
gorogergo
Oct 1, 2005 01:20 AM
mdp61377
Jun 23, 2005 02:13 PM
