wrong dip stick reading???
Old Mar 25, 2019 | 07:23 PM
GMJim's Avatar
Default wrong dip stick reading???
I always seem to be busy when I need to change the oil in my wife's car (2008 C30 T5) so she takes it to the dealer. Recently after her last change I had to add 3/4 of a quart and thought the dealer short changed her so I decided I would start doing it myself but ran into a little problem. The car calls for 6.1 U.S. Quarts so in goes 6.1 quarts of Amsoil 5W-30. The dip stick shows it needs another .9 quarts? I called the dealer to double check the capacity and also check that the dipstick was correct P/N 30777500 and it is. We've owned the car since new so nobody changed the dip stick tube. Any ideas?
Thanks Jim
Old Mar 26, 2019 | 08:36 AM
is the dipstick sliding all the way in? check if the rubber cuff at the top is in the proper position.
Old Mar 26, 2019 | 08:51 PM
GMJim's Avatar
Yep. O rings are in good shape and the stick goes all the way in.
Jim
Old Jan 2, 2022 | 02:09 PM
odrg's Avatar
Default Wrong dipstick reading? Engine takes more oil than specs.
My 2012 Xc60 3.0T specs are 6.8 liters but it takes 7.4 Mobil One 5w30 Syn to top up the dipstick. Why? Same with my 2009 C30 2.4l. Is the container from Mobil overstating how much oil is in it?
Old Jan 3, 2022 | 10:04 AM
richardkonrad's Avatar
Leave it for a few days and check then , many garages overfill these cars for the same reason , there are many oil traps in these motors , PCV etc and they need the whole day to settle proplely , many of these cars have oil leaking and gaskets broken due to overfill
Old Jan 3, 2022 | 03:20 PM
One thing to try on your next oil change is to measure what you drained out and compare to what you added in (filter change adds about half a quart per most liturature). Also check the capacity for with and without a filter change. Funny thing for me is on my car, It takes less than the spec to get to the top line.
OurVolvo
May 30, 2018 12:34 PM
mudpie
Sep 6, 2013 05:22 PM
ldkVolvoXC90
Jul 14, 2013 09:09 PM
redrex
Nov 10, 2011 12:39 PM
Sepp
Jan 25, 2009 09:56 AM
