03’ T5 C70 issues :(
Old Jun 4, 2025 | 04:46 AM
jRabb1t's Avatar
Default 03’ T5 C70 issues :(
Hi guys,
Just wanted to ask about if you can try to fix two things with my Volvo, one is more of a diagnostic job.
First thing is the drivers side window fell down a few weeks back and I fixed that by changing the regulator cable , it was relatively okay after the repair apart from the window being a bit forward, but now something is scratching the window from inside the door, I know there is many adjustments you have to make on the regulator to make it work right, would you guys be able to help with that?
Also have an issue with the soft top as it is a convertible, the top comes down completely fine but doesn’t come back up completely, it stops right at the end where it needs to latch down at the back, I have to manually wind it from the boot, previous owner said that one of the sensors is the issue but I know there is quite a few of them and don’t know where to start, also might be a cut wire on one of them?
not sure if anyone would be nice enough to help out here
thanks everyone
Old Jul 19, 2025 | 01:34 PM
tedders's Avatar
Hi.
I hope you've fixed it. If not, my best idea is to take it to the dealer and find out how they repaired the problems. have them go into details, so you know what they did, and how you can di it yourself.
Tedders
Old Jun 3, 2026 | 10:15 PM
28CarsLater's Avatar
There are a number of sensors in the body and they can short out over time. I haven't had that specific problem so I can't elaborate too much on it, but I can tell you the roof tool used to program them is unobtanium. From the little I read about a few years ago, when those sensors go bad some people take the covers over and replace or fiddle with them and sometimes it will work again without being reprogrammed.
Michael mic
May 26, 2016 01:40 PM
Michael2
May 1, 2016 01:14 AM
JCTNC70
Aug 12, 2014 06:14 AM
quietlymknnoise
Feb 17, 2013 05:15 AM
djoker04
Jun 30, 2011 03:35 PM
