'04 C70 Convertible - Windows dropping on Ignition on or off
Old Jul 16, 2015 | 10:36 AM
Vighpyr's Avatar
Default '04 C70 Convertible - Windows dropping on Ignition on or off
So this problem began happening a couple of days ago and is a weird one. I searched and saw a couple of similar problems, but didn't see any real solutions.
When I start or turn off the engine, when the key gets to the center position, all four windows go down. I can put them back up either individually or using the 'all windows' switch, so the switches seem to be working properly. If I hold the switch in the up position while starting or shutting down the engine, no problem. Or... if I turn the key quickly from off to on or on to off (not pausing in the center position), the windows stay up.
Any ideas?
Thanks!
Old Feb 13, 2019 | 05:22 AM
mike16's Avatar
Any ideas?
Thanks!
I joined this forum for exactly this problem. I am in England with a 2004 C70 convertible. When you turn ignition to position 1 or 2 all 4 windows open. You can close them and carry on but very annoying. Did you ever solve the problem?
Old Apr 6, 2019 | 05:42 AM
teebone's Avatar
From: Lower East Coast of NSW( approx 155K's from Sydney City.
Hi There I'm a newbie...I'd be checking your Ignition switch, can you Imagine how many times that poor thing has been switched on? I worked for Volvo, this is new to me However I'd go for the simple things first, My Driver side window on my C70 would not go up, so I sprayed the channels with silicone spray, problem solved. I was quoted $200 for repairs.Silicon Spray $2:95 au.
tomilvento
Oct 4, 2021 06:09 PM
gnstuckey
Feb 13, 2019 07:04 AM
Ron T.
Apr 29, 2018 08:17 AM
Saab194
Oct 15, 2017 02:59 PM
signstar24
Jan 13, 2008 08:08 PM
