C70 won't start
Old Jan 10, 2008 | 10:27 AM
signstar24's Avatar
Default C70 won't start
Help- I,m stranded- key will notturn to the start position. It will turn to have the radio come on and then won't go any further. I have jiggled the key and steering wheel and nothing.
any suggestions?
Old Jan 10, 2008 | 10:53 AM
JimKW's Avatar
Default RE: C70 won't start
I'm not sure, but I moved this to the C70 Forum. Better chance to get help there.
Old Jan 10, 2008 | 08:04 PM
Eric J's Avatar
This seems chronic, read this thread: https://volvoforums.com/m_89328/tm.htm
I'll bet it is the ignition switch.
Old Jan 13, 2008 | 04:12 PM
NathanFJ's Avatar
Which model is it?
I used to have a C70 hardtop, just sold it actually. Mine had about 115k miles on the clock when i had this problem. If it is the same as I had it is purely mechanical. You can get by for now by dismantling the cover over the steering wheel (two torx bolts) and then disconnect the ignition switch from behind. Ensure that the key is still in the ignition or a)steering lock may engage and b) immobilisermayfunction. Using a flat screwdriver you can rotate the ignition switch through to starter and then once the engine is running bring it back one click to the run position.
I had a new ignition fitted from genuine parts to suit my original keys, it cost me about £250 from an independent volvo dealer. It's a pain to fit as the original part may have to be sheered or ground off.
Hope this helps you! Good luck.
Old Jan 13, 2008 | 08:08 PM
Eric J's Avatar
Welcome to the forum NathanFJ.
Thanks for the discriptive info, keep it coming.
Gustav
Nov 11, 2017 01:01 PM
volvoralph
Jul 19, 2016 04:19 PM
exotek
Nov 11, 2008 09:32 AM
dkh c70
Apr 25, 2006 11:52 PM
