09 c70 tpms
Old Jan 7, 2015 | 07:37 PM
RichyRich's Avatar
Default 09 c70 tpms
Just bought the car. Dashboard says, "Tire Pressure System Needs Service." All 4 tires have the proper pressure. How can I tell if a rim does not have a sensor on it. One rim has a rubber valve stem. The other three have a chrome valve stem. Could the one with the rubber stem NOT have a sensor on it? Also I did try the "reset" button on the turn signal stem.
Old Jan 7, 2015 | 11:40 PM
damien360's Avatar
The one with the rubber valve stem sounds like it doesn't have a sensor.
Old Mar 2, 2015 | 10:18 AM
RichyRich's Avatar
what brand sensor should I get? Volvo OEM or will an aftermarket one do the job?
Old Mar 2, 2015 | 10:38 AM
TPSMs have transponder frequencies. you just need to match the Volvo spec (I think its 433Mhz ). You should be able to find an after market. I know FCPEURO sells both OEM and aftermarket as does Tire Rack. Figure $60-70 for the unit, some require a stem kit to match.
Old Mar 3, 2015 | 01:43 AM
RichyRich's Avatar
thanks for the information mt6127
FredRydr
Nov 13, 2016 06:32 AM
garydrenk
Sep 18, 2010 12:05 PM
garydrenk
Sep 18, 2010 12:02 PM
garydrenk
Sep 18, 2010 11:57 AM
fstrdr
Dec 4, 2008 10:01 AM
