1998 Volvo C70 (need some help)
Old Apr 12, 2012 | 10:29 PM
ghost3487's Avatar
Default 1998 Volvo C70 (need some help)
So I was in at the local Volvo mechanic who has been around for over 20 years. And there are some interesting things going on with my volvo that I need to have fixed ASAP but I have no cash and need to do them myself. So please help if you can.
1) Low beam headlight is out (high beam works) BUT, when I checked the fuse it wasn't bad. The only bad fuse that was in the fuse box was the front cigarette lighter.
2) I am having a problem with high idle (900-1000 rpm). How ever I have found that the peddle causes some of the problem, so I was wondering on how to fix that without getting a new cable. Was also told that the idle air sensor (which is $200) could be causing it.
3) With this vehicle how do I check the PCV system? I know there's a valve but with this car I dont know where it is. :S
Other than that there's a bit of lifter noise but put in a bottle of cd2, so that should clear that up.
Old Apr 15, 2012 | 04:00 AM
MSGTUSMC's Avatar
1. Are both low beam headlights out?
2. High idle - Idle Air Control (IAC) valve testing - use an ohm meter to measure resistance between connector pins 1 & 2 and between 2 & 3 - should be 10-14 ohms, if not replace IAC. Voltage - ignition ON - pin 2 to ground should read battery voltage, pin 1 to ground should read 6-8.5 volts, if not, replace IAC.
3. PCV - B5254S, B5234T, B5254T,B5254FT,B5234T3 ENGINES - Volvo refers to the PCV valve as: the flame guard. Disconnect the negative battery cable. Remove the throttle pulley cover. Udo the hose clamp and remove the inlet hose to air cleaner housing. Remove the flame trap (PCV) from the housing by rotating it 0.59 inches (15mm) to the left. Remove the flame trap from the inlet hose using a small screwdriver or pick. Inspect hose for clog. Blow out hose with compressed air. Change engine oil after replacement.
Old Apr 15, 2012 | 04:06 AM
MSGTUSMC's Avatar
Default Volvo C70 Repair
Haynes 3573 book Volvo S70, V70, & C70 1996-1999 (P -V REGISTRATION) Petrol.
Chilton 72302 Volvo Coupes/Sedans/Wagons 1990-98
Both books handy, more info in one book than the other depending on the topic of repair & pictures!
Old Apr 16, 2012 | 08:41 PM
ghost3487's Avatar
1) no just the driver side low beam. Checked the fuse and its good. :S
2) good to know will do if I can find myself an ohm meter for cheap. :/
3) I just checked the vacuum on the car. And its got nothing but vacuum. So it cant be that.
Now the code thats reading is a P0410, and when I did the research it said that it was a secondary air injection system. And I have a feeling this car is going to be a pain.
Old Apr 16, 2012 | 09:03 PM
MSGTUSMC's Avatar
Harbor Freight or Northern Tool sell cheap ohm meters. Radio Shack, Lowe's & Home Depot carry them also.
Change the light bulb in the headlight?
Old Apr 18, 2012 | 10:42 PM
ghost3487's Avatar
Yes, changed both bulbs, checked the fuses. Found out yesterday morning driving to work that the lights would dim and brighten. Any ideas?
Old Apr 18, 2012 | 10:43 PM
ghost3487's Avatar
GOOD NEWS! Found a rebuilt smog pump on ebay for 155. And a new egr as well.
Old Apr 20, 2012 | 06:25 PM
ghost3487's Avatar
okay I got the OHM meter and now I just need to know what settings to have the meter on to check the IAC. :/
Old Apr 21, 2012 | 07:48 AM
MSGTUSMC's Avatar
Default Volt Ohm meter
Vehicles run on a 12 volt DC battery. Use DC volt setting!!! Never seen a battery in a car before? Read instructions for voltmeter!!!!!
Old Apr 21, 2012 | 07:49 AM
MSGTUSMC's Avatar
Thumbs up
Use ohms settings to read resistance. Google OHMS LAW !
Old May 11, 2012 | 11:04 AM
ghost3487's Avatar
Changed the smog pump, and the egr check valve. And I still have the same problem with the smog pump failure code p0410. Any ideas?
Old Jun 13, 2012 | 12:34 AM
ghost3487's Avatar
Alright, so I did a bit of looking. And the $18 one way check valve was missing entirely, thus its replaced.
not only that I also replaced the smog pump selenoid as it was bad.
Other things I checked:
IAC (1-2) was reading 11.3.
IAC (2-3) was reading 13.4.
Should I replace the IAC if its reading that low? Because its popping codes too and is also causing a high idle (so I was told by the local volvo mechanic).
thermostat sensor is also popping codes every once in a while. so I figure down the line I will just replace both.
Lansdowne
Sep 22, 2014 01:02 AM
jderosa3
Mar 20, 2011 03:01 PM
Sanel30
Feb 18, 2010 09:16 PM
volvos70t5boy
Mar 25, 2009 10:38 PM
B1mmer
Dec 18, 2006 11:24 PM
