2008 c70
Old Sep 19, 2016 | 07:01 PM
Pski694's Avatar
Default 2008 c70
I have a 2008 C70 that bought from my neighbor. It cranks but will not start. I had the timing belt, tensioner and water pump changed. The shop that did the timing belt is having a hard timing figuring out why it won't start.
No codes stored in ECM. Any suggestions?
Old Sep 20, 2016 | 04:44 PM
MSGTUSMC's Avatar
Needs fuel & spark. Check injectors & coil packs. Testers available @ Advance Auto. Make sure shifter is being recognized in park. Check ignition switch, easy to access & remove. Battery should read 13-14 volts. Remove positive battery cable for a full minute then reconnect. This will reset ECM. Good luck & let us know what happens. A lot of smart people here to help better then me.
Old Sep 20, 2016 | 06:49 PM
Pski694's Avatar
Today test fuel pressure at the rail. Pressure is good but injectors are not responding. Any ideas on injectors not responding?
Old Sep 21, 2016 | 02:39 PM
MSGTUSMC's Avatar
Default Injectors
Check all fuses. Advance Auto & other auto parts store can rent U a NOID tester to test you injectors. Remove & replace all injector connectors, if all are failing suspect electrical problem. You can lift up fuel rail, crank engine & C if rail is working, then lift rail with all injectors connected & C if you are getting a mist out of each. It is simple to build your own injector setup/tester.
Good luck.
Old Sep 27, 2016 | 10:45 PM
Pski694's Avatar
Well found that the compression is shot. Dry is anywhere from 90 to a high of 130. Wet all cylinder were about 220. Bought a replacement engine for $1800 with 50k miles. Going to put all new timing components on the new motor.
Taurkon
Dec 3, 2008 06:52 PM
znguy
Sep 23, 2008 04:49 PM
3anchors
Feb 3, 2008 01:02 PM
hguirguis
Jan 24, 2008 07:14 PM
carlc70wny
Jan 11, 2008 11:13 AM
