80000 miles, some general maintenance questions
Old May 29, 2009 | 09:11 AM
bek's Avatar
bek
Default 80000 miles, some general maintenance questions
Hey guys,
I just bought my C70, but was unable to get the maintenance history on it. I changed the oil immediately and the air filter was a little dirty, but not bad. The battery and alternator tested fine.
What else do I need to think about? I'm thinking at this point:
transmission fluid change
timing belt replacement
new plugs
Anything else? Can I use plugs of my choice?
Any general (or specific) advice you guys can offer would be greatly appreciated.
Thanks,
Brian
Old May 31, 2009 | 10:47 AM
elav's Avatar
If you are doing the timing belt, replace the engine seals there too. I would also replace the water pump although a lot of people say not to bother unless it is leaking. I would also flush the coolant, replace thermostat, serpentine belt and replace the brake fluid. You might as well replace the cabin filter and possibly replace the top engine rubber damper if the rubber has cracked.
You will most likely have to rebuild the front suspension in the next 20K miles.
Old Jun 1, 2009 | 01:12 AM
bek's Avatar
bek
Thanks, Elav!
That looks like a good, strong list. I am going to have to do them a few at a time, I think, but I'll get 'em all eventually. Much appreciated.
-Brian
HankG
Mar 1, 2014 03:36 PM
Downshift6932
Jan 8, 2012 10:49 AM
volvomang
Aug 22, 2009 01:14 PM
TheTippelskirch
Mar 6, 2009 11:13 AM
XC9O
Jun 28, 2008 06:58 AM
