another strange noise
Old Jun 25, 2007 | 11:10 AM
fritzlovesmary's Avatar
Default another strange noise
hi again,
since 2 days i have a strange noise with our 1999 c70 coupe. hope i can describe it in a rather understandable way. it sounds like heavy single raindrops(which i haven't seen here in the desert yet) or bugs hitting the car - but the noise comes from the front to the middle underneath the car, mostly on the passenger side - but sometimes i thought it comes from behind the dashboard too :banghead: . it is there with ac on or off, fan on or off and only while i drive, can't see or hear anything while standing and idling. looked underneath and in the engine area, but can't see anything that might cause it.
does anybody here have an idea what that could be?
thanks
fritz
Old Jun 25, 2007 | 05:40 PM
Default RE: another strange noise
Maybe sway bar link.
Old Jun 25, 2007 | 06:32 PM
how can i check that - where is that sway bar link?
thanks
fritz
thanks
fritz
Old Jun 25, 2007 | 06:33 PM
oops, sorry for double posting .....
Old Jun 25, 2007 | 06:44 PM
You would have to jack the car up and secure it on jackstands then check from under the car.
The link goes from the swaybar to the strut.
Pull on the sway bar on the ends and feel for play. There should be none at all.
If one is loose you will usually hear it click when you pull on it.
Old Jun 25, 2007 | 08:44 PM
thanks tech - did it, but everything is fine.
have to travel from barstow to vegas tomorrow (2 1/2 hours), see and hear what happens.
thanks
fritz
Old Jun 25, 2007 | 08:49 PM
When you get time also opne the hood and where the strut comes through the body try turning the 13/16 nut.
If it spins the strut cap/upper spring seat is broke.
If it won't spin and feels rubbery it is good.
Old Jun 26, 2007 | 12:02 PM
tech, checked that and it is ok too. it is kind of hard to describe the noise properly - sometimes it sounds like when something is heating up or cooling down and it makes that cracking noise with it. or it sounds like something could be loose and banging to the underside of the car (almost like a whind chime) while driving - but i checked underneath and couldn't see anything.
thanks
donf
Jul 4, 2012 08:47 PM
96960Chris
Jun 25, 2011 04:49 PM
Flying torquewrench
Jan 8, 2006 11:20 PM
Tobex
Aug 16, 2005 12:57 AM
jwr2480
May 19, 2005 11:25 AM
