C70 seats will not move
Old Jan 11, 2014 | 05:20 AM
Dave Playfair's Avatar
Default C70 seats will not move
Hi this is my first time so not to sure the problem i have is my driver seat is not working its an electrical fault (motors not working
Old Jan 21, 2014 | 06:12 PM
Ksagal's Avatar
did you check the fuses? On my car, I believe that fuse is in front of the driver, but under the hood. (smaller of the two fuse boxes)
Good luck.
Old Jan 22, 2014 | 09:39 AM
GabrielleGriswold's Avatar
Mine always take forever and a day to move and sometimes just say "screw it" and not move at all. Hope you figure out whats wrong.
Old Jan 23, 2014 | 01:49 PM
MSGTUSMC's Avatar
Default seat
What year is vehicle? Mine is a 98, 44k miles
Old Feb 5, 2014 | 09:03 AM
adrongo's Avatar
Default seat wont move
Hi I had the same problem once 0n my 1998 C70,there is a toggle type override switch low down on the right hand side of the backrest that has to be fullover to allow the electrics to work, (you can reach it by hand) Open up the seat cover (leather/cloth and secure the switch with a strong elastic band then the electric drive will work.(originally this rotary switch was held by a small spring). Hope this helps.
Old Feb 8, 2015 | 12:35 PM
Racerxc70's Avatar
On both seats in the back where they pivot there is a micro switch it is activated by a plastic nipple which is infamous for breaking, there is a fix your dealer or a Volvo mechanic can help with that OR you can do what I did and remove the seat ( I removed both to save future headaches ) and wrap wire around the micro switch so that it will be always on ( the switch is there for safety reasons
dexbla
Apr 9, 2013 02:14 PM
GZipper
May 28, 2012 06:59 PM
laur9400
Feb 9, 2011 08:41 PM
AzNick
Nov 6, 2010 06:49 PM
